Deuce Turn Signal Bulb replacment #?
Darwin T
10
Port Arthur, Texas
i have been searching for the bulb number for little bulb in the turn signal switch and the only part # i found said it was the same as the dash light bulbs (it is NOT). aua i pulled the bulb and it said 24volt 3amp on the side. does anyone have the bulb or part # that they will share? :beer:
i hate to start a new post for something that the first responce will probably answer but i can't find it. :-(
ratat98
Shattuck, Oklahoma
I had the same problem with my turn signal indicator light.
I took it down to the parts store and after searching the "big book" (I rarely see the "big book" pulled out) for about 15 minutes, the owner managed to figure it out, and now I have a box of 10 of them sitting in my garage! Might try that approach...
73m819
319
gainesville, ga.
Would you mind shareing the p/n and id info
1,174
As simple as looking at the -20P TM. 1873 bulb
Use your TMs!
cranetruck
75
Meadows of Dan, Virginia
The turn signal indicator bulb is grounded via the mounting strap (hose clamp?) to the steering wheel column, so make sure you also have a good ground connection for it while you are at it.
Prankster
Ponca City, Oklahoma
Question?
Is it possible to install an inline ballast resistor to step down the voltage from 24V to 12V ???
Okay, how about two ballast resistors?
I was just thinking there might be an inverter that would allow a 12V bulb to be used on a 24V system.
rosco
Delta Junction, Alaska
With that bulb in mind, I'm missing the little shield/cap, that covers that indicator bulb, on the turn switch itsely. It just snaps in place. Its not something that one can buy new, without getting the whole switch. If anybody has one sitting around in a parts truck, I would be greatly indebted. If you think that light is bright at night, try it uncovered. The way it sticks out, I am afraid I will bump and break it. I wiil look for a PM.... Thanks a million
Darwin T
10
Port Arthur, Texas
i disconnected my air buzzer and put a light in the dash so i would not have to listen to it, i think i will stick with the light. however, that is a great idea, i just have enough noise.
steelandcanvas
85
Southwestern Idaho
What do you have when the light burns out? You actually don't have to listen to the buzzer, it's the perfect time to do a vehicle walk-around. Check the tires, pull the battery box out and have a look, check your signals, tail lights, and head lights. I wouldn't want to sit there and listen to a buzzer either, but I can't see disconnecting a factory designed and installed safety device. Just my 2cents.
1,807
I have both the buzzer and the light. If the short duration of noise from a low air buzzer bothers you, might want to get a different vehicle. Case in point, had some little fingers take the cover off and open the service brake valve on the deuce once. While going down a series of hills I depleted my air supply. Traffic was to heavy to watch lights and without the buzzer bad juju could have occurred. Buzzers are mandatory for me.
Darwin T
10
Port Arthur, Texas
My 2 M35a2's still have the buzzers. My M109a3 has the factory designed safety device (Dash Low Air Light) and all i have to do to install the buzzer back is plug in the one wire that i don't reinstall when i added the (LED) light right next to the air pressure gauge. and sometimes i even wear earmuffs to protect my hearing. within 75 miles of here i don't think there is about 40' difference above sea level. my M109a3 is parked at about 4' above sea level and my M35a2's are 45 miles away at my farm and are about 32 feet above sea level. the steepest thing i drive across is a bridge and when i had brake problems on the bridge it was not air problems. if i was in the mountians or hills i would probably have put it back.
