deuce wheel stud
welldigger
Benton LA
If there's anywhere that builds rock crawlers near you check them out. Here local I have a place called kryptonite kustoms. They supply me all of my Rockwell axle parts. Google them and go to their website. I know for a fact they stock wheel studs. Can't tell you the price tho.
rosco
30
Delta Junction, Alaska
Check the heavy truck store in your area. Best to take it out first, and take what is left of it to match the one on the bench. That was a good stud too. No sign of an earlier crack, before it broke. When you check the rears for tight, you have to loosen the outside nut first, then tighten the inside one, then re-tighten the outside nut.
Ford Mechanic
Edenton, NC
I know this is a real stupid question but, what's the torque spec for the lug nuts? I haven't seen it in the TM but I might have missed it. Has anyone ever broke one from the over tightening them? I've just been tightening them as tight as I can get them with the 5 ft breaker bar.
1,183
Thank goodness for DOT regs and inspections. They use a torque wrench. I'm sure this has significantly reduced failures and road safety.
1,183
Perhaps I should elaborate.
I have no issue with a 200lb guy using a 4' pipe and guessing he put almost 100lbs of force on it, to get to 350 ft/lbs.
But to just use a long bar and put all you have on it and stop when you hear a noise, I think is piss poor advise.
In the example above, do you see how easy it would be for the same 200lb guy to over tighten them by 100%? That will cause a failure eventually, for sure.
You must use some finite input, not sound. (what torque value does something "pop"?)
o1951
155
Bergen County, NJ
TM 9-2320-209-10-4, page 39. http://test.steelsoldiers.com/upload/M35/TM9-2320-209-10-4.pdf
Five foot breaker bar and standing on it should be about right. 325-350 foot pounds.
Whoa! TM -"325 to 350 pound-feet". Dressed, with boots, I weigh about 210 pounds. Most of you are probably in that range. If I figure right, standing on the bar about 19 inches from the center gets me in range. End of 5 foot bar is more than 3 times 350 ft/lbs max.
DH - My response is to post 25. You responded while I was writing.
Ford Mechanic
Edenton, NC
What about us light-weight's?:-D 170lbs dressed out:mrgreen:.
In all seriousness, how should I get them that tight? I've never seen a torque wrench that big! I've never looked for one either. We do have a torque multiplier here at the shop, but I tried to use it removing the lugs that I couldn't get off and it was still a no-go the pipe it had was too short. If you've got a torque wrench that big, where and $? At the moment all I've got is the Snap-on 1/2 impact, a 5ft breaker bar and a 6 ft piece of steel pipe that I tackle lug nuts with. My truck is singled with a set of the front axle style lug nuts on the rear tires now.
porkysplace
1,494
mid- michigan
Quit drinking light beer and hit the gym :roll:
1,183
marchplumber
3,034
Peoria, Illinois
Amazing, how something so simple can cause so much consternation! I did find them locally, but their prices were higher than a large MV surplus dealer. So, I ordered a complete sets L and R. They will be here in Two days. Disappointed in the locals, but they set the price not me. Their loss. THANKS for the help, the info that DH gave really got the ball rolling on this end! Thanks DH!
God bless,
Tony
o1951
155
Bergen County, NJ
I have a torque wrench that goes to 500. The method we described works well in the field. 170# and 2 feet out is close.
At home, DH post 31 - torque stick is good enough. Here is a torque wrench that will do the job.
Wright 0-600 Ft. Lbs. Dial Type Torque Wrench 6470
Regular Price: $884.32
On Sale For: $530.59
Shipping Weight: 16lb
Quantity:
Wright
Size 0-600 Ft. Lbs.
  • Weight 14.00
  • Drive 3/4"
  • Torque Range English Foot Pound 0-600 ft. lb.
  • Grads. English 10 ft. lb.
  • Torque Range Metric 0-800 Nm
  • Grads. Metric 20 Nm
  • Length Inches 46-1/2"
  • Wt. Lbs. 9-1/4
  • No. of Ext. Handles 1
Woodsplinter
Phoenix/AZ
Check out lugwrench.biz. I bought a torque multiplier from them last year for $160. It has a 58:1 gear ratio and all the sockets you need for a deuce. Removal is extremely easy and you can torque them back on by using a standard torque wrench with the multiplier. It comes with a form to tell you how much torque to use. 13 ft/lbs in = 350 out, etc.
The price is still the same but now they have on with a 78:1 ratio. Needs no air, and fits in the tool box. There's also a video on the website to demonstrate the tool.
peashooter
205
Hanover, minnesota
I second Woodsplinters recommendation. I also bought one of these and its nice. Think I paid around $150 shipped off ebay, it includes the sockets needed for the nuts and square thimbles and is small and fits in the truck better than the stock lugwrench does.
Ford Mechanic
Edenton, NC
Got one of these lug wrenches. Works great!!! But I didn't get the form.
Is this correct?
Ford Mechanic
Edenton, NC
If you got the newer version with a different gear ratio, these numbers won't work. I'll be happy to scan & post it or email it to you.
Thanks man, but yeah I bought the 78:1 ratio one, they were out of the 58:1. I checked the website and all I saw was there new "half back" method of tightening your lugs. I reckon I'll email him and find out for sure.
