- 3,022
- 223
- 63
- eldersburg maryland
well you should not be confused, what you did was replace the HH. different from assymbling an untimed engine. the key here is that the red tooth is not a timing mark, it is a removal mark for the HH.
to replace the HH set the red tooth in line with the arrow and then DO NOT TURN THE ENGINE until the job is done.
to time everything, set all the other marks correctly, ignoring the red tooth except to be sure the ip is on the correct revolution.
