- 34,010
- 1,827
- 113
- GA Mountains
Wikiwikiwiki
That would require it to be FINISHED!!!How about some final walkaround pics of the finished product ?
I swore he said it was a done deal...That would require it to be FINISHED!!!
Nope he just took some time away from it. Dont worry maybe oneday he will mount his window switches...
Oh c'mon... I know he hasnt mounted the window switches yet!!! Or put a toolbox between the bed and cabDiablo has been completed..
Mike is still working on the CUCV..
Marie
Well I got the power stuff in today... I don't know who designed these motor assemblies but I would swear that they had a Deuce door on the bench when they were doing it because they fit PERFECTLY! You could install one of these in 2 hours!
Im glad I have the door as an extra to play with because you don't need to do nearly as much cutting on it but the intention was to be a little more informative and give lots of working room, the actual install will be a lot less wide open. I have to bend up a hat section for the lock solenoids, if you consider installing them you will have to build a cover panel for the door due to not having enough space with the glass (I will show this in later pics).
Overall I couldn't be happier with both, I was worried about the glass weight, crappy parts, etc but its pretty bullet proof. The speed on the window is great, factory auto glass doesn't move this fast!!!
I will have to take a drive up to Orlando this weekend to do the sheet metal work I could hand fab what I need but a shear and brake which I need for re skinning the top will make it much easier... Hopefully on Monday I will have everything mocked up in one solid piece...
LOL. Here was the next one!Very nice craftsmanship for sure!!..............thats a lot of work though to just end up with a bobbed duece. Hope your next build is very unique..put that talent to work....good job.
I will see if I can scare up that information. I know that each of the seats has a sub-woofer blasting super low frequencies up your arse.Have a question about your seat bases if you still look at this thread. what are the dimensions and also is the box made of wood with the metal rails? or some L shape angle iron on the bottom to mount? thanks
