Did all the 4 speed hmmwv come with the 4L80
Agelai
Get some
64
13
Florida
Did all the 4 speed hmmwv come with the 4L80?
What would be the difference between this 4L80 transmission, and once that would be in any car with the 4L80?
Mogman
8,990
Papalote, TX
Yes the 4 speeds are 4L80 and not much different than any 4L80, some use different torque converters and different tail shaft configurations. And of course different programming in the TCMs
springer1981
1,148
Maine
Not all 4L80's are created equal. There are early and late models and there were running updates. At some point they added a bolt hole for LS engines. Then the 4L85 is an upgrade planetary but still a bolt in for a 4L80. When I was looking for one for my HMMWV I found the 2000ish and up were a better choice and went with that. As for bolting it in, I also decided a take out HMMWV was a better choice than piecemealing it together since it already had the right lines, linkage, etc.
  • Like
Reactions: 98G
Getpro56
California
From what I have seen, all 4 speed HMMWV's have a 4L80 in there. Big difference when replacing a transmission was which TCM matches that transmission. This was a pain since there were about a dozen different nsn's for HMMWV transmissions out there and each had its own TCM. Nowadays there are only 2 nsn's for the 4L80 transmission on HMMWV's. Legacy A2/R1 "heavy variant" like the 1097 and the up-armored HMMWV's like the 1151.
A2/R1:
Trans - 2520-01-489-0849
TCM - 2520-01-579-1379
Up-Armored:
Trans - 2520-01-489-0850
TCM - 2520-01-579-2302
TNDRIVER
451
Cleveland,TN
A2/R1:
Up-Armored:
What vehicle uses PN 12563695, 57K6233, NSN 2520016579861. Inquiring minds would like to know.
Action
1,555
East Tennessee
A2/R1:
Up-Armored:
As far as I know, the only difference in the different year TCMs is shift points. So you can just drop any one in and go.
Getpro56
California
Looks like that transmission PN 12563695 (2520-01-657-9861) came in a kit for the M1097A3 which I have not seen. I am not seeing much information on FEDLOG either. PN 57K6233 (2520-01-625-7876) is a replacement transmission to the 2001 year model which NSN is 2520-01-489-0850 (Terminal Item).
TNDRIVER
451
Cleveland,TN
About what I found, no use on code for it. 1097 rebuilds in TX. 4L80e is one tuff box and the items to upgrade a 2000 and newer to 4L85e are available. THANKS
Getpro56
California
Never heard that one before.
Threw a few of us off when we replaced a transmission on an 1152. Couldn’t figure out why it was happening. TM wouldn’t explain it either. I believe PS Magazine had an article on it it.
springer1981
1,148
Maine
A 4L80/85 will default to 2nd gear. It isn't so much a limp mode as a default. I found this out when doing my 4L80 swap and talking to the TCM controller tech support to make sure I was setting it up correctly. It displayed 2nd upon power up and that didn't seem right to me so I called. After a discussion with a very knowledgeable tech at the company he explained many aspects of how it works and this was one of my question.
I suspect the Limp mode is basically any aspect of the controller not working such as a sensor or power and the transmission defaults back to 2nd gear as opposed to the controller saying "hay something is wrong, lets go to 2nd gear so I can be limped home".
Mogman
8,990
Papalote, TX
Any number of things can put you in the limp mode from a bad sensor or wire to no power to the TCM, you can pull every electronic device and wire and it will be in 2nd gear all the time it is in drive.
4x4Junkie13
24
La Vernia TX
A2/R1:
Up-Armored:
I know this is an older post but I just picked up an M1123 (2009yr) and it is missing the TCM.
These aren't really A2's but use the 12k halfshafts as they are considered the heavy variant.
Would I use the 2520-01-579-1379? (I am assuming the best way to be sure is to go look at the trans for the number)
52
26
Aguanga, CA
I would consider upgrading to a newer TCM. When my TCM failed due to water in the waterproof box I decided to go with the transmission kit from Black Dog Customs. This way you are using a modern controller instead of the older box. I have put over 6,000 miles on mine since I installed it and the install is pretty simple and straightforward. It took a couple hours for the install.
86humv
496
Texas
There is an early and late 4L80E...most hmmwv's have the late one.
Tcm's if good will all work...its just different shift times.
Elijah95
Certified Rookie
1,239
1,183
Georgia
Go with the black dog stand-alone kit, better with tuning on the fly, better diagnostics, shift point adjustments, allllll kinds of goodies. I just installed one on a buddies truck, why spend 800 on a “new” TCM when you can go brand new with a warranty and has upgrades etc for a few dollars more?IMG_0915.jpg
