- 3,657
- 27
- 48
- Dallas, Texas
I add 1 quart of straight 30 wt non-detergent oil. It's cheaper than the $6 per quart additives.
Hey Op that sounds like a goodun.I add 1 quart of straight 30 wt non-detergent oil. It's cheaper than the $6 per quart additives.
Dude, do you have a tractor/lawn tractor/etc? If so then pull your tank bungee cord it to one of the wheels of your tractor and then fill it with a handfull of gravel (sand and itsy bitsy pieces and all) and a couple quarts of muratic acid and you'll be done with it after your next cutting.Thanks for the reply maybefixit! I really have to deal with the rusty tank issue more than anything. I may try muriatic acid because only the bottom of the tank is rusty - probably water that sat in there for ages. I imagine I would have to flush the tank out over and over with water after the muriatic acid treatment and them blow dry the tank afterwards. I will try the Sea Foam to clean the injectors and lines because I have heard that is what it does best. Still waiting for our local NAPA to get my fuel filters in right now.
Alan
