DIY custom wheels??
HN6
401
alaska
I searched and didn't find anything. Any posts on cutting/making own custom wheel? Yes, Do not try this at home. I understand the safety precautions.
thanks,
cattlerepairman
3,233
NORTH (Canada)
Well, the search turned up quite a few threads. Happy reading.
Also this:
Member montaillou did some recent research on custom rims. You may want to tap into his knowledge as well.
HN6
401
alaska
Also this:
Well, guess i need to get better at that for starters.
Thanks,
tobyS
832
IN
Isuzu budd 17.5", 19.5" and 22.5 are out there but the height OD on the 17.5 and 19.5 is only about 30-31". I've picked up a few for M105 axles but of course the 6 x 8.75 fits deuce too. Maybe the 22.5 is an alternative that would be higher on a truck (don't have any). Also, they may be a source of the inner portion for the cut and weld wheel people. Note on the 17.5 and 19.5, on an M105, the overall width is 8'2"....just under the legal limit. Salvage yard has some of the 17.5 for me but I don't have them yet. By my measure, they do fit over the 105 brake drum but I have not tried yet. Here is the 19.5 on an M105 axle. I know this is a thread about the deuce, but the 6x8.75 is same.
wallew
posted this April 2018 about the route I went - I went with steel wheels made for my duece. Not cheap, but got EXACTLY what I wanted.
The company that made them is wheels now inc and the particular wheel is their # 219
Just another option - hey, it's only money that you will likely spend one time if you do it right the first time. That is how I approach purchases like these. One time purchase of a quality NEW product will never be as cheap as surplus. OK by me.
  • Like
Reactions: HN6
montaillou
812
W.WA
thanks,
I have researched wheels extensively. What are you trying to accomplish? I should note, my research was for wheels made by commercial manufacturers. I'll be blunt and say home made wheels are something you do for enemies.
If you're talking about commercially available wheels, your biggest issue is our bolt pattern. Your choices are to stick with military wheels or find a blank wheel and have it drilled. You could also swap out the hub, but I can't see that ending well for your wallet.
  • Like
Reactions: HN6
HN6
401
alaska
The "wallet" is the only reliable source so far!
A few threads on cutting and rewelding the wheels pretty easy and straight forward. I weld for a living, so if someone else is getting paid to weld them at their shop it should go fine for me. It will not be quick but
tobyS
832
IN
Seem like there should be an Isuzu going to a boneyard with those wheels in a 22.5 .
  • Like
Reactions: HN6
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
Old thread with very good contributions, here:
  • Like
Reactions: HN6
HN6
401
alaska
Yes sir! You posted that on page one for me I believe. I have read each one at least 4 times. Looks pretty straight forward. Greatly appreciated.
