Shankem-Deep
- 16
- 18
- Ada, Oklahoma
A little update on my Harbor Freight 12000lb winch. I had the replacement installed for a few weeks before I actually got to put it to real use. My father in law called me and said he had his tractor stuck in a creek and needed my help. I quickly drove over and hooked up the winch and started pulling him out. Everything was fine until the winch really got to pulling the full load. It quit on me just like the 1st on did. It wouldn't even pull the line in without a load. I ended up just wrapping the cable around my shackles and just pulling the tractor out with my truck and a chain. Fast forward about 2 weeks later and I finally get around to start taking the 2nd winch off to return it. I thought I would try it again before I took it off just to see. To my suprise it worked! I was standing in front of the truck using the wireless remote watching it and noticed some smoke then it quit again! I looked where the smoke was coming from and realized that the terminals were grounding out on my skid plate! I had the skid plate too close to the terminals! I thought about this when I built the skid plate. But thought since they had rubber covers over the terminals and weren't actually touching the skid plate that it would be fine. They were just too close to the skid plate and ended up touching. I temporarily used some washers to space it away and the winch now works fine! I've pulled out a buddy of mine who was buried up pretty good no problem! The winch is slow but works well. The first winch I had was most likely just fine, I just missed the problem.
