Do glowplugs make any noise when they go bad?
edpdx
80
Oregon
And, does leaving the key switched to the ON position- as if listening to the radio flat burn up the gowplugs. I let my daughter take my truck to school while hers was down and didn't think to warn her not to do that.
original
Pineville, West Virginia
I've never heard a noise come from a bad plug and yes leaving the key on for more than 30 seconds can burn up the glow plugs. Time to get a GP tool and start replacing. Save yourself some trouble and wire your accessories to run without the key and turn them off when parked.
doghead
4 Star General /Moderator
1,193
NY
The instructions for starting on the drivers side visor says not to leave the key on, or GP damage may occur. It is also said in the -10.
Yes to making a sound when they burn out. In your case it should sound like a phone ringing, then a familiar voice saying, dad, the truck wont start.
mistaken1
Kansas City, KS
No noise.
From the TM 9-2320-289-20 manual:
CAUTION
Do not leave key in "RUN” position for more than 2 minutes. Failure to
follow this caution may resuit in damage to glow plugs.
JUNKYARDJOHN
somerset ky
Thats priceless Doghead... made me spit coffee all over my keyboard this morning. :mrgreen::mrgreen::mrgreen: John
NICK_M1009
Brown City, Mi. (The Thumb)
The nice thing about these trucks is that they have seperate pipes. When you start it and you see one side is still smoking after a few you can tell which side you have to check, narrowing it down to one side. Hopefully one plug goes out at a time.
glcaines
2,806
Hiawassee, Georgia
Are you hearing some sort of noise, or just asking the question? If you are hearing some noise, it should not be the glow plug.
edpdx
80
Oregon
glcaines, yep, I actually did hear a noise before I took the old Direct Drive Starter out. It was a kind of sizzling bacon sound. Just once when I turned the key. I have not hear it since; but then again the new starter in not running right yet either- I have a new solenoid I am putting on today. I just can't help thinking that noise accounts for some damage yet undetected.
What about the circuit board that goes with the glow plug circuit, does that burn up with a cooking sound?
ps. My daughter drove the Blazer home ok, so I don't know that the key was left in the run position too long. I was just trying to account for the starter going bad.
glcaines
2,806
Hiawassee, Georgia
I would make sure you have good clean connections on both batteries and every other high amperage connection from the batteries. Also check the batteries ground connections and the engine ground.
