82ABNMP
- 53
- 28
- Winston Salem NC
Doghead relay...2 purple wires? ...now hard starting
Doing the starter relay mod as I've done many times but this time no purple/white stripe wire to tell the 12v with the on. I tried to test both wires but neither one reads 12v with the key on. I did cut the wire harness apart to try and fine the purple/white wire with no luck. This truck has had problems cold starting and the GP system was not working when i got the truck. Any advice would be appreciated. Red wire does have 24v.
David
David
