TropicalThunder
- 0
- 0
- Pago Pago
What is the purpose of this Mod?
Look at the pictures at the end of this threadWhat is the purpose of this Mod?
Thanks,Look at the pictures at the end of this thread
http://www.steelsoldiers.com/showthread.php?60960-doghead-starter-relay-modifcation
and this one
http://www.steelsoldiers.com/showthread.php?70846-Poll-Who-has-done-the-Doghead-Relay-Conversion
While some people over a long span of time have never had an issue with the starter relay (originally was an air conditioner relay) many people have had the relay fail (like in the pictures). I personally have seen three relays fail.
Will yours fail? Maybe not. Is it possible? Yes. If it does fail, the starter will engage all by itself and continue to run until the starter burns up or the wiring lets the Smoke Genie.
You and only you can make the decision to upgrade the relay or not. As usual YMMV.
If you search cucv starter runaway you will want to make sure its been done.Lots of horror stories,mine included,It doesn't happen to all of the cucvs but if it does you will wish it hadn't.Thanks,
I'll look at that but I think previous owner might have done something. theres a huge starter type relay hanging on the bottom center of the dash. that could be his attempt at fixing it.
Cheers
You want a 12V relay anyway.How difficult is it to buy a 24 volt relay?
I felt the same way about cutting off a good connector only to put a new one on.In regards to the starter relay mod, I wanted to know if anyone has ever made a harness pigtail for the relay so that the existing harness connector could be maintained. Yeah, I know, just cut the connector off and crimp on some terminal lugs. I just have this aversion to cutting off the connector if there is a suitable way to use it.
The connector on the harness is probably female, so is there a corresponding male connector that I can buy? Has anyone taken apart the original starter relay, and if so, does it look like it would be possible to make it into a connector for the new relay?
30 amp cont, 50 amp intermittent at 14 VDCWhat amp rating is that relay?
I don't care to debate it.
Are you going to market these new hack-less relays? I am interested in one for Terminus M1009.30 amp cont, 50 amp intermittent at 14 VDC
If I remember correctly, I measured the current draw on my truck, it was about 9 amps when the starter was engaged.
