Double Deuce crew cab
ccequipment
Unionville,IN
Its going to be getting some 15.5's and my custom 2 piece bolt together wheels that I sell. I am also going to install a power steering, as I have plenty of them laying around here to here is a pic of a tire and wheel.
ccequipment
Unionville,IN
Got some more done on it yesterday, we got the top pretty much done, I thought it turned out pretty good. I used a 4' wide piece of 16 gauge for the splice, and then added 3 struts across the top to stiffin it up out of 1-1/2 angle. Makes a good solid top out of it that way, I put about a 1.5" arch in the top for further support. Also I took a picture of the rear cab mount I made, using a similar design as the factory one, but it will allow me to put the bed a little closer to the truck. I have some welding to finsh on the top, and with any luck we will get some sort of step system and the fuel tank installed today
ccequipment
Unionville,IN
It will have a price tag on it, but plan on driving it, but I said that about the last truck I built for myself, and only got to drive it 2 times before someone else wanted it worse than I did:-D
BFR
Rocket Surgeon
2,330
42
North Georgia
I keep imagining this not bobbed with a 105 bed that has had its wheel wells removed.
How much frame do you have left behind the bed?
ccequipment
Unionville,IN
I have left the frame full length, it worked out perfect for the 9' M105 bed. I ended up with about 11" between the cabs, looks like there will be plenty of leg room, and of course I am planing on sliding the drivers seat back for the big guys. Here is a few pics with the bed set on temporary. Got all the steps and fuel tank mounted today. I also added some struts inside the cab to hold the side from moving between the doors. Whats your guys 2 cents between the steps. I thought about closing it in with sheet metal, but I think it looks ok the way it is. It will need to flex at some point anyway and you really could not tie the 2 together solid, it would have to float. Should be rolling tommrow.
drjconley
merced, ca
Are you going the lengthen the rear drive shaft? If so what technique are going to use? If you are going to lengthen the drive shaft could take a few pictures, it would be appreciated.
Thanks,
Jim Conley
davesgmc
131
Mclouth, KS
at this point you will be putting final paint on by the weekend wont ya? SLOW DOWN! your making the rest of us look bad. lol
ccequipment
Unionville,IN
Thanks,
Jim Conley
Looks like I am going to need about 7' of tube, I will proably just weld in a new tube. I have a machine I use to turn the shaft while welding it.
1,821
I'd not join the boxes at all. What I think would be cool is a slide out tray/compartment there. You could use it for all kinds of storage or just a rack for some 50 cal or 20MM ammo cans. That would be way cool.
tm america
24
merrillville in
looks good not sure i would have went with those braces maybe a cool looking roll bars would have been better that way you could have put some three point seat belts in there to.ammo cans would work out or you could make some dummy panels.or put some gerry can holders and just do so extensions on the steps .the gerry cans could sit side ways and would come in handy for extra water ,:roll:
