brazengoat06
- 2
- 16
- Tulsa, OK
Wondering if anyone has figured out a way to run dual alternators and still add on an AC Compressor? Seems like if one could fab up some brackets and get creative that it could be done.
I got the CUCV dual alternator kit from nostalgic air for $1049. It is a complete kit and well worth the price. It comes with all the vents and all the parts you need to install it. I later had to move the compressor when I installed a banks sidewinder turbo kit. I still wanted the dual voltage so I had to purchase a dual voltage alternator from AC Delco to keep the 12 and 24 volt systems. I moved the compressor to the passenger alt mount and the new dual voltage alternator bolted up on the drivers side alternator bracket. Just something you might want to consider if you plan on getting a turbo in the future. I can post pics and details if you would like.
They have several amp ratings. I am running a 105 amp. I use the 24v side to charge after starting and glow plugs and to run my 2 16" radiator fans. The 12 volt side charges and runs everything else. I have six LED work/drive lights that put out 2400 lumens, a 12v air compressor, 3k/6k inverter, a 400w inverter, and a nice stereo. I haven't had any problems yet. The alt uses a trans former on the back to generate 24v it essentially doubles the output of the alt for your 24v side.Thanks ill give them a call tomorrow.
well I have an m1010 that someone before me removed the duvac and swapped the accessory drive to that of a regular cucv. I just need to add a compressor so that I can utilize the rear a/c. I also need to be able to take both alternators because of all my lights and of course a/c blower. what kind of amps does that single dual voltage alternator put out? maybe I can just run that setup instead.
