hot rod deuce
- 0
- 0
- Kasota, Mn
well if you sending id take one, and get you something for your time as well
Id sure be interested in a copy too. :yeah:Crazyguyla said:i have this manual: SMARPI 9-2320-209-14&P SPLIT AIR-HYDRAULIC BRAKE SYSTEM (MODIFIED M44A2 2 1/2 TON SERIES TRUCK)
if anyone would like a copy, drop me a line. it tells how to rig the daul system and parts needed.
if anyone can tell me how create a PDF file, i'll didgitize it i'm just not smart with acrobat.
I have uploaded this to the TM section and has been approvedCrazyguyla said:i have this manual: SMARPI 9-2320-209-14&P SPLIT AIR-HYDRAULIC BRAKE SYSTEM (MODIFIED M44A2 2 1/2 TON SERIES TRUCK)
Did you ever get an answer to your question?I know this thread is old, but did anyone ever used a M105 brake for the rear axle as the first poster mentioned?
I have one idea about using the brake system off of a M105 trailer to work one axle on the truck. Separate the rear tandem and run it off a M105 (or commercial) air actuated hyd master cylinder. This can be controlled off of the trailer air supply line. Then if you loose brakes on the front two axles, you will still have the park brake and the rear tandem.
Thanks Mike ...
