Dustless Media Blasting
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Has anyone else used this? They use a crushed glass water slurry mix. I just had my M37 bed done ($250). After talking to the guy and looking on the net; it is way faster than regular blasting and takes 1/6 to 1/10 of the abrasives normal sandblasting would use. They claim to be able to do a car in 1-2 hours with 8-9 bags of crushed glass. It also looks like there are companies spread across the country.
1,823
Wonder how much different it is from the sandblaster attachment for the pressure cleaner?
Warthog
240
OKC, OK
I looked into buying a unit. Around $40K with a compressor (up to $75K for a big unit).
~$5K for a small unit without a compressor. And up to $30K for the largest unit.
hndrsonj
365
Cheyenne, WY
yep, 15K is the number I found. It doesn't distort the surface either.
Warthog
240
OKC, OK
http://dustlessblasting.com/products.html
Without compressor
DB150 - $5995
DB225 - $8250
DB500 - $11500
DB800 - $14500
DB1500 - $21500
DB3000 - $29500
With Compressor and trailer
DB500 Mobile - $39500
DB800 Mobile - $49500
DB1500 Mobile - $72500
Dual DB800 Mobile - $74500
These units require a LARGE compressor. Minimum is 185CFM and usually needs a 335CFM
