DWF exhaust pipe question
tgejesse
289
Maryland
Sorry to revive this old thread.
In 2017, I bought a well-used (rusted) DWF exhaust. At that time, there were only early, unarmoured Humvees auctioned off, so I was completely sure to have the exhaust for the non-armoured trucks.
Now recently, I wanted to finally fit the restored exhaust to my (non-armoured) M1045A2 USMC slantback, and to my utter surprise, it seems to stand out too far from the body. However, I didn´t loosen the rear muffler, so I´m not entirely sure.
With a bit of wiggeling, I was almost able to squeeze the bolts (which are welded to the exhaust) into the rubber grommets, but then the exhaust would not be parallel to the body in the vertical.
Did I really get an armoured truck exhaust ? Is there any way to clearly identify the different versions of this exhaust ?
It’s about a 2 inch difference
cut it, weld it and mount it!
AAVP7
263
Dortmund, Germany
That´s why I have doubts which version I have. When I press the exhaust tube against the flange on the muffler, it seems to be about an inch too far out, not two inches.
I just want to make sure which version I have before I cut perhaps a perfectly OK non-armoured exhaust, just because the muffler is badly aligned.
Is there any measurement I could take to verify the version ? Or are the welded-on bolts an indicator of one version ? The manuals show that only for the non-armoured version; the armoured version seems to have holes and extra bolts.
AAVP7
263
Dortmund, Germany
OK, I sorted this. With a helper, it was no problem to first attach the exhaust flange to the muffler with the three bolts, and then push the two upper bolts into the rubber mounts on the body. Took a bit of a queeze by two lads to press the exhaust inwards enough to get the nuts on, but it worked.
And the exhaust is more or less parallel to the body, so I´m sure now that it is a non-armoured version.
I´ve taken a measurement of my exhaust; might help somebody in the future when in doubt if he has a armoured or non-armoured exhaust:
The measurement is pretty rough, so don´t quote me on the exact millimeter, but I understand the armoured exhaust stands out two inches more, so 50 mm, and that is a noticeable diffence.
VermontM998A1
Arlington, Vermont
Good morning,
I am will be purchasing a deep water exhaust kit for my 1994 M998-A1. I see a lot of questions about armored vs non-armored exhaust. I have a non-armored vehicle and based upon the TM I will be ordering part # 12339849. Is it still possible that I will received an exhaust that stickes out too far from the fender and will need to modified?
Any info is appreciated.
Greg841
84
WI
12339849 was the part number I ordered and mounted without armor. Like someone else mentioned mounting it took a little pressure to get the bolts started, but its parallel to the body when everything is tightened down. I did it myself, a helper would've been nice.
Lawdog734
127
Colbert, GA
My truck came with the armor removed, but the armored DWF exhaust on. Quite frankly, it looks goofy standing off from the body with spacers, so I cut and welded mine so that it sits up against the body like it's supposed to.
