Another Ahab
- 4,968
- 113
- Alexandria, VA
It sure looks good. ![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
I'm starting to miss the nightly updates on all of the projects Cucvrus is working on.
cucvrus is in the pokey?!He'll be back.
For how long, is up to him.
10 infraction (points) in 3 years. Less than half of them given my me.
Spaced apart long enough to only get short times off.
What the hail did he do to deserve such punishment? Doghead please explain so the rest of us won't make the same mistake!He'll be back.
I believe all members can look at another members "infractions" when looking at their profile info. Maybe only us moderators can(not sure).What the hail did he do to deserve such punishment? Doghead please explain so the rest of us won't make the same mistake!
Looks like he has 2.5 days left, until he may return.Infractions/warnings:
When a user steps out of bounds, the board has a feature to give what is called an infraction to users. There are two levels of this. A warning and a point bearing infraction. A warning is simply "Please be aware that you shouldn't do that". A courtesy notification if you will. A point bearing infraction is a "ticket". These tickets last for a year total. Repeat offenders will have a compounding effect. The repercussions of an infraction are as follows:
1 point = just a point, but you keep it for a year.
2 points in 365 day period = 1 day ban.
3 points in 365 day period = 1 week ban.
4 points in 365 day period = 1 month ban.
5 points in 365 day period = permanent ban.
Discussion of infractions is between the member and staff. Not public debate. *We reserve the right in extreme cases to bypass these steps and permanent ban a member if warranted.
This is the mix sheet from the PPG sealer i am using F3985 Fleet service grey sealer. Firefox was asking. The paint is Lusterless Alkyd enamel. Got it as outdated paint from a military base. They were discarding it. Turned it in to Safety Clean. Go figure. i seen them discard unused new ATF and motor oil.Such things are not only in your country.i seen them discard unused new ATF and motor oil.
Who's coming over?I will post pictures tomorrow. I have an M1009 Mule to complete. It is supposed to be warm and sunny. Not damp and dreary. Take care and have a great day. I am expecting a visitor from a fellow member tomorrow.
Today I had the glass company install the windshield and rear window back into the M1008. It was $80. Easier to pay $80. then struggle and break it by myself. Besides it was tough enough for him to work back in. The window rubber had shrunk quite a bit after being out the past 2 years. No damage to new paint was another reason I left a professional doing. Money is like a tool when you use it wisely and correctly the job gets done right.
I opened all the new lights. They look very nice.
Painted the rear tail lamp housing with bright aluminum.
I changed the light sockets. The grounds have been bad for a while. The wire was stripped and forced into the socket to ground the bulb. It worked.
Done for the day. 10 hours today was enough. Have a great day.
