Electrical connectors source
Steel Soldiers is supported by:
dcowan
Rogersville, MO
Does anyone have a good source for the rubber plug connectors (I've seen them called packard, and deckard). Looking for the rubber boots and the internal spades. I ordered what I thought was correct on amazon and they turned out to be same size rubber plugs but the metal connectors were not the same size as whats on my truck.
spankybear
20
WA
First off are you talking these connectors here?
They have a pin and socket instead of a spade.
If you are looking for the ones above...There are a few places out there... I just ordered some form Big Mike's Motor pool .com. You can find them on ebay and there is also Erik's military and Industrial surplus. Use the mil satandard number for find then in a search engine. Note the "dash" number is the wire gauge.
  • Like
Reactions: art
dcowan
Rogersville, MO
Yes those are the connectors and the ones I ordered looked like this also but the pin sizes were wrong.
spankybear
20
WA
I only have 14 ga here so I can't check... maybe the pin and socket size is not the same between 12, 14 and 16 gauge. Maybe someone else can chime in.
