Farmallmilitary
- 0
- 16
- Las cruces nm
Ok well let me just tell you i hate wiring and electrical systems. My truck has got me stumped (not hard to do) but i was going around today fixing and replacing various lightbulbs. When i got the truck ALL the turn signals worked and i am sure of it. So today walking around the truck the left rear turn signal light wasnt working. Naturally i check the bulb an see if it is good and it was. The socket where it goes in has power on the meter with a steady spike of electricity each time the signal cycles. I then cleaned the contact points and still nothing. I then remembered it was the same bulb as the brake light so i put a brick on the brake and the light comes on. I am guessing it may be a dirty ground on the turn signal or a loose connection but i cant find any. The problem is it was working not but 2 days ago.
Next on the electrical system is the horn. When i push the button nothing happens no click or sound. So i thought it could be the button in the steering wheel and i cleaned it up and soaked the contacts in CLR. Still nothing. I am guessing there is a fuse but where is it? I wish electricity was simple.
now comes the oil pressure guage. When i first start the truck in the morning the oil pressure guage is almost straight up and down (60psi) and once it warms up to operatong tempurature the needle is pegged at the 120 psi part. If the guage is at all correct then i have a major problem as i know the pressure is supposed to be somewhere around 15 psi at idle. Would it be the guage or the sensor sending unit? All electrical engineers welcome at my house. Ha ha
