Antonio Pena
- 7
- 8
- Florida
Hello, is there anybody’s out there that can help me find a electronic governor control for a MEP 804B any help would be greatly appreciated Thanks
Is there a Quad Circuit fuse installed in the set?
The quad fuse mod is to protect the A1 volt regulator. It has a fuse in it to keep the A1 from over volting.
I’m dealing with an MEP 804 B the attachment is different?The quad fuse mod is to protect the A1 volt regulator. It has a fuse in it to keep the A1 from over volting.
Look at Guy's document, page 5 of 7, for 804A.I’m dealing with an MEP 804 B the attachment is different?
I mis-spoke, or better said, mis-wrote, here. The fuse protects the Quad winding FROM being damaged by the A1 volt regulator. But if the fuse is blown, the A1 will not take over the function of producing voltage. The installation of this mod is the same, no mater what set its installed on. My intent here is to make sure that we take this step by step. If the fuse is there and blown, replace it. If the set works, good. If it blows again, you have a bad A1. If the fuse is not there, install one, and try starting again. See if it blows again. Or, if it is good, and no voltage is produced, then we need to see if the Quad circuit is damaged.I’m dealing with an MEP 804 B the attachment is different?
