74M35A2
- 317
- 83
- Livonia, MI
Just wanted to post some info for anybody wanting to add hydraulics to a truck that does not have such. This pump can be had with 8 rib serpentine or double V belt clutch. Muncie brand, all cast iron. Rated at 11 GPM @ 1000rpm, near equivalent to a 925 I believe. Easy 2 bolt mount, ports are rear or side. Would easily fit the 8.3L compressor bracket I make/sell (just sayin’). Not cheap, about $550 new, but gives a lot more flexibility in PTO activation, as you can literally flip it on while driving down the highway (that can be good and bad). The Muncie website is terrible at part number cataloging, so great if this helps any of you.
https://www.munciepower.com/cms/files/Products/Literature/Documents/Brochure/MP88-06.pdf
