Engine block heater Where to buy?
akexc
Eudora, KS
I have a 5 ton with a 465 multi fuel. Where can I get a block heater to install in the freeze out plugs. They are 2"plugs
Rob ... _._
Did you have any luck tracking this down?
I've done a search in this forum, and don't find a thread that helps me. I have a 5 ton multifuel dump.
Thanks.
sprucemt
15
Warrensburg NY
You need to ask for a frost plug heater for an Olds 455 V8 from the 80's or a Jeep Cherokee 4.0L six from the 80's. 2" is the correct size. Napa uses Pyrol heaters, Katz is a good brand also. I've been using these for years ad have been satisfied with them,
