ok dude... TM9-2320-289-34P
1 PAOZZ 11862 1403394-6 STUD,CONTINUOUS THR 1
2 PAOZZ 11862 14033945 BRACKET,ENGINE LIFT FRONT 1
3 PAOZZ 11862 22535073 STUD,CONTINUOUS THR 1
4 PAFHD 11862 14067734 ENGINE,DIESEL FOR COMPONENT PARTS 1
SEE FIG'S 2 THRU 11
5 PAOZZ 11862 14033947 BRACKET,ANGLE REAR 1
6 PAOZZ 11862 11504595 SCREW,CAP,HEXAGON H 2
7 PAFZZ 11862 14037861 SPACER,PLATE 2
8 PAFZZ 11862 6262212 NUT,SELF-LOCKING,EX 2
9 PAFZZ 96906 MS90728-60 SCREW,CAP,HEXAGON H 6
10 PAFZZ 96906 MS27183-16 WASHER,FLAT 18
11 PAFZZ 11862 9440344 BOLT,MACHINE 8
12 PAFZZ 11862 14055501 BRACKET,ENGINE MOUN LEFT 1
13 PAFZZ 11862 9422299 NUT,SELF-LOCKING,HE 12
14 PAFZZ 80205 NAS1408A6 NUT,SELF-LOCKING,HE 6
15 PAFZZ 11862 9440356 BOLT,MACHINE 4
16 PAFZZ 11862 459021 MOUNT,RESILIENT 2
17 PAFZZ 11862 460308 BOLT,MACHINE 1
18 PAFZZ 11862 14071967 BRACKET,ENGINE MOUN LEFT 1
19 PAFZZ 11862 14055502 BRACKET,ENGINE MOUN RIGHT 1
20 PAFZZ 96906 MS90728-61 SCREW,CAP,HEXAGON H 6
21 PAFZZ 96906 MS27183-13 WASHER,FLAT 6
22 PAFZZ 11862 6262211 SCREW,CAP,HEXAGON H 1
23 PAFZZ 11862 14037878 BRACKET,ENGINE MOUN RIGHT 1
If you do part cross search by 1984 GM Pickup they have the mounts you need at gmpartsdirect.com
Mount, all - 6.2l, diesel - 6.2L, DIESEL 84-87 $40.00
$40.00
At lmctruck.com
LMC Truck Parts - Page 125
The 6.2 has only one set of mounts. I spoke to a buddy today who worked on all sorts of CUCV's and said all the mounts are identical. GM and LMC have the parts you need. he mentioned something that the mounts for the 350 worked best for some reason.
and again... this has been discussed in detail in other threads....
http://www.steelsoldiers.com/cucv/16543-motor-mounts.html
http://www.steelsoldiers.com/cucv/2421-6-2-motor-mounts.html
