Engine Oil Fuel Dilution Problem
Doodster
WI
Back in February I had a problem with diesel getting into my engine oil. The fuel compensator was already bypassed so I change the three o-rings on the hydraulic head. They were cracked and in bad shape. I monitored the engine oil levels and they did not move. I sent in another sample in August and the fuel dilution is back again. I assume its now getting in through the Injector Pump. Where can I get a rebuilt one or someone who rebuilds them. Currently online I have only found them for $800-$1000 which is too steep for my pocket book.
Also I have oil leaking out of the hole under the clutch. My guess is that I havent seen an increase in oil levels because its leaking out the engine seal.
Here are the critical areas in my Napa oil test
Lead is 43ppm (up from 14ppm in February)
Viscosity is 8.2 (5.1 in February, so it slowed down some)
Luke
fsearls92
149
International Falls, MN
There are special o-rings that have to be used for the hydraulic head, which if I recall are viton o-rings that will not degrade like your normal o-rings. Did you use the proper o-rings? How bad is the oil leak out of the hole in the bell housing? That leak will most likely be from your rear main seal that is pretty easy to replace, but you have to pull the transmission. I did the rear main when I put in a new clutch assembly, since others on this site had recommended doing it. Also back to the fuel leak, have you removed the flame heater? This could also possibly be your fuel dilution problem. It could also have been just reminants of the fuel left over in the motor from when you initially changed the oil after replacing the o-rings.
RAT
13
Marietta, GA
Main fuel pressure pump drive seal. If new rings in hydraulic head and if it runs the head is not the source.
Pull pressure pump, run tank pump, watch for drip.
Welder1
156
Albany Ga
If the hydraulic head O rings are good and the control shaft O ring is sealing then the only other place likely is the booster pump. It has a shaft seal keeping fuel separate from the oil side. The AMBAC repair data says to test the pump with 30 PSI air and submerge in water to detect any leakage. To remove the booster pump the engine will have the be elevated and pulled towards the pass side some.
Doodster
WI
I am going to check the o-ring on the control shaft first. I had this feeling it didnt fit as tightly as it should.
