Back in February I had a problem with diesel getting into my engine oil. The fuel compensator was already bypassed so I change the three o-rings on the hydraulic head. They were cracked and in bad shape. I monitored the engine oil levels and they did not move. I sent in another sample in August and the fuel dilution is back again. I assume its now getting in through the Injector Pump. Where can I get a rebuilt one or someone who rebuilds them. Currently online I have only found them for $800-$1000 which is too steep for my pocket book.
Also I have oil leaking out of the hole under the clutch. My guess is that I havent seen an increase in oil levels because its leaking out the engine seal.
Here are the critical areas in my Napa oil test
Lead is 43ppm (up from 14ppm in February)
Viscosity is 8.2 (5.1 in February, so it slowed down some)
Thanks
Luke
Thanks
Luke
