bones1
- 4
- 18
- Southern Maryland
Good questions Ferro.
If you are asked to start your truck by a dot officer and you do not push in your clutch you just failed your inspection . that is the last thing im going to add to this because if you argue with a truck driver you will soon realise it is like throwing a pig in mudd " they like it"I've been driving large trucks for a long time, 6 days a week for 10+ years, and have never pushed the clutch in when starting. My newest kenworth has over 200K miles without a single problem. My brother owns 6 semi's, and 2 medium duties, he said has never pushed the clutch in when starting. The transfer station where we all dump our trash has 32 trucks. Each one is started every morning, and none of them get the clutch pushed in during starting. They just do a walk around to each one quickly. We all stand outside the truck during starting. We stand on the step, fire them up and look at the oil pressure. We then get out and air tires, fold tarps, load chains, etc....
NOW, with this truck I need to get back into the habit of depressing the clutch while cranking like a regular pickup. I wouldn't want it to run away if something locked up or went wrong. I've seen guys crank a big truck with air brakes, while it was in gear. It just jerks the truck.
I don't want to argue the depress vs not to depress in this thread because you guys are right. It is better. But....it is definitely not a must when the truck does not have a mechanical problem. Very few of the millions of over the road trucks are started with the clutch pushed in.
Ferro...you are right. I'm not sure about the smell. She must be wrong. She is pretty good at knowing different automotive smells though. She had thought she smelled brakes before, when it was a clutch. Inside the truck there wasn't much odor. Anyway, I should know this evening. I'll finally have time to get out to the truck and work on it. My friend didn't feel comfortable pushing in the clutch and trying to crank the engine. He wanted me there.
When I was working DOT only the chicken**** guys did stuff like that. Unfortunately there were LOTS of those guys.If you are asked to start your truck by a dot officer and you do not push in your clutch you just failed your inspection . that is the last thing im going to add to this because if you argue with a truck driver you will soon realise it is like throwing a pig in mudd " they like it"
LOL! We both said the same thing. We couldn't believe that both of us missed it. It is actually hard to see it where it is on the block. That, and when we looked the night that it happened we had been awake for almost 48 hours, it was 27 degrees, and we were just ready to get the truck home. Tonight I started working in order like others had listed. I checked clutch, trans, generator, air compressor, and then went back to looking for ANYTHING. I can't believe it, but no oil was dripping from that spot after it happened. I posted the picture that I took 5 minutes after it ventilated itself. There was oil from the bell, and out of the crankcase vent.I gotta ask, how did you miss that? Well at least engines are all over.![]()
I was thinking the exact same thing.Spend the extra and buy an LDS engine for it. Moar power.
I definitely like that idea. I think my fiance will kill me though. She was really looking forward to riding in it. She has her first fitness/figure contest in April. Her and some of the other girls wanted to dress in little camo shorts and tops and take pics with the finished truck.hndrsonj said:Seems like a very good reason to strip it down to the frame and repaint/bob.
I know that. And not all meth heads are truck drivers.Not all truck drivers are meth heads!![]()
