Loose Deuce
- 0
- 0
- South MS.
this my first post in many years so here goes. My deuce has been sitting up for several years because of health problems and just plain laziness. It started but ran bad, made it about 100 feet and it shut down and cant get it to run. It will try and run when spraying Either in the Air Intake, buts that's it. I had that off road diesel that has the red die in it. primary filter was slimed up (changed to spin on filter) replace both secondary filters that looked good too. Took fuel tank off and pressure washed it out and check out the in tank fuel pump which I replaced the rubber hose on pick up to the pump too. Replace fuel lines from tank to primary filter and then to Fuel Injection Pump. I bled all the air out of lines with that bleeder valve. loosen all the (fuel injector) lines at the injectors. they were too hard to get a good check because I didn't remove the line brackets and they were too stiff to get loose enough. anyway it was showing seeping around the injector line fittings so I figure they were getting fuel but cant be positive without loosening all the lines fittings properly. Well that's about all I can do myself so far. I'm thinking there's something wrong inside my injector pump ?????????? that all I can think of so far. And the fuel I drained out looked nice and clear except for the red die.
any one knows about this sort of problem and know how to fix it ??????????????
