AJMBLAZER
- 8
- 0
- Paducah, KY
Well, then JCW should be cheaper.
Yep, a single 3" will out flow a similarly bent 2.5" dual setup every day. Less surface area in the pipes to cause drag/backpressure.I have a civy blazer that had a gas engine in it so I swapped a CUCV 6.2 and 400 trans into it.The truck already had a 3 inch flowmaster exhaust so I bolted the stock 350 crossover pipe to the 6.2 manifolds bolted the exhaust back together and it works great.
