Fifth wheel question
73m819
327
gainesville, ga.
according to the -15-1, heigth for the 818 fifth wheel is 56.3"from the ground and for the the 819 it is 54.3"
westfolk
157
PA
If the fifth wheel is in that area off the ground you're good. Every truck is going to vary depending on what suspension, tires and fifthwheel are used
Towman2277
Saraland, Alabama
That 5" will not make a difference.... the length that is behind the fifth wheel towards the back will. If your converting a truck, i'd keep it as short as possible. Tommorow I will measure the length from my fifth wheel to the end of the frame and post it on here....
westfolk
157
PA
Steve has it right. Add to that what terrain you may be planning on running. A good rule is to have the frame long enough to be able to mount flaps behind the tires.
m.walker
Independence,Mo.
My M52 is 56" , according to tm 43-0001-31 your M757 is supposed to be 55 1/4". My M750 ( 15,820 lbs. ) and my friends M127 ( 14,400 lbs. ) sits level on mine so you shouldn't have any problems , when you hook it'll drop some due to trailer weight . Plenty of tire clearance also so you shouldn't have any issues there . I'd love to see some pics of it hooked to some trailers for comparisons , I'm curious about the turning radius from the foot longer wheelbase of the M757 ( 206" ) compared to my M52's ( 194" ) , still not as long as M819's ( 242" ).
73m819
327
gainesville, ga.
the 819 is so long, even a 172 is about the same length, it will be a real production backing up those short trailers, need a football field just to swing the front end to keep the trailer going where i went it to go, after i bought the 819, i found a old rogers lowbed real CHEAP that i was going to get till i mersured the trailer from king pin to center of axles, it was about 10' longer then the 819, right then and there i know that was not going to work
Scrounger
69
Southern, Maryland
Just have to remember overall height. For commercial trailers that are 13'6" 5th wheel height can't exceed 47 1/2". When I towed a 12'6" trailer with my 818 the overall height was 13'4"'.
NEIOWA
128
NE IOWA
If you ever see a mil 5t (M813 or new) pulling a 6t semi trailer or the older model stake trailer you'll note the nose is "too" high. The 5th wheel height on the 5T is higher that the trailer design.
73m819
327
gainesville, ga.
thats because those older trailers used 900x20 tires and ment to be pulled by a 2 1/2t tractor
cranetruck
92
Meadows of Dan, Virginia
Thanks for the information!
Walker, according to the TM 2320-230-10 manual, the turning radius is 42 ft 2 inches (with winch). Guess the weight of the winch on the front axle will add some resistance to turning. Without the winch , it's 41 ft 4 inches.
Remember that both front axles steer on the 757, which may effect the actual wheel base when making comparisons.
