Fire Extinguisher
SandM1010
Franklin/MA
Does anyone know what's inside the fire extinguishers that were used in the CUCV trucks? Are they safe to still have in the truck? I have 2 that were in my M1010. Both appeared to be filled with a liquid and seem full, there's no gauge. Curious if they could have become hazardous over time. thanks I will Take a photo soon and post.
D6T
536
Vermont
Are you sure they are fire extinguishers and not DS2 sprayers?
The decon spray bottle would contain DS2, which is caustic, I forgot if it’s closer to hypochloric acid or bleach.
(Neat fact that most people would never guess: instead of a pull pin to secure the handle against accidental discharge, the spray bottle has a lead plug that’s intended for the user to just squeeze the handle through in order to use it.)
A fire extinguisher contents may possibly be determined by its appearance. A label with the NFPA classification may or may not be present.
A red body with a hose or short barrel likely indicates water or dry chemical.
A rigid “horn” that swivels is for CO2.
A small silver body and metal hardware, with a short hose or barrel, is likely “purple K” for grease fires and combustible cooking by-products—found in kitchens but not CUCVs!
A larger silver body and hose is likely water, a neat can to have around as you can fill it with water and pressurize with a common air pump.
This has been your daily lesson in such things, brought to you by someone who’s been in both NBC and firefighter roles.
Crazyguyla
124
Altus, OK
DS 2 is its own corrosive nightmare. I remember packing leaking canisters in vermiculite. DS2 and bleach, big bad fire..
jasonjc
289
Gravette Ar.
Purple K is for fuel fires and would or could be in a CUCV. Now a "class K" fire extinguisher is more for use in a kitchen.
20,762
i looked closer at the label on the second one, its CF3BR Halon.
Halon is the good stuff. We have about a dozen of them posted around our computer equipment. Still need to disconnect the power to stop the fire - but Halon is the thing to use to extinguish fire in a computer cabinet. It doesn't make the gosh awful white powder mess like the "ABC" dry chemical extinguisher. AND you can still breathe after using Halon too...
Elijah95
Certified Rookie
1,246
1,221
Georgia
Funny story, had a co worker set off the halon charge in a massive server room. We both nearly suffocated before we made it out. Good times
Buck Wampum
143
33
SE PA
I replaced the OEM extinguishers in my V-100 with new Halotron ones. I'm not betting my vehicle on a 1960's fire extinguisher, no matter what the gauge on it says.....
