First recovery from Ft. Leonard Wood, made it home
73m819
329
gainesville, ga.
put one end in tank fill and tie off, other end clamp to in fitting at filter
I would use one of your trailer air lines as a temp hose.
73m819
329
gainesville, ga.
If you have to put a hole in the fill screen, do it so you can get hose to near bottom of tank.
1,193
Yes, the strainer unthreads off the tank.
73m819
329
gainesville, ga.
I am sorta posting, not knowing what tools he has, the bare minimum for what he needs to get going, he has anything more is a +.
1,193
A screwdriver used as a chisel, may spin it off(loosen it).
A leather belt or rubber engine belt.
1,193
I'd be curious to know what happens if he tried to bleed the fuel system with the manual pump.
Is there fuel in the tank?
1,193
Cold there?
Using fuel additive?
Has the filter been changed recently?
swiss
956
Oakwood, Ga
Cool a help thread with a good title and NOT HELPPPPPPPPPPPPPPPPPPP,
You are in good hands with DH and 73M819
Location would also be good in case members are near by and bored :)
Warthog
245
OKC, OK
If the vent line is plugged and the pump is causing a suction, just loosen the cap and see it it will run.
Warthog
245
OKC, OK
He is on a recovery from Ft Leonard wood MO. Heading back to the NE corner of Oklahoma.
1,193
Threads merged, background helps.
