Fixing Out of round Tires
dawico
Lampasas,TX
Not trying to change the subject, but can CTIS output pressures be adjusted; like in HWY mode it inflates to 60 instead of 70 or 90?
That is a good question. Searching for info on this I found two replacement valves, one was for 70 psi and one for 90 psi. That doesn't suggest that they can be adjusted. I am curious as well.
Csm Davis
401
Hattiesburg, Mississippi
...but the TM says CTIS HWY Mode is 90PSI right? Right.
Certainly any tire can be dangerous at any PSI, personally
I do what the TM says usually which is a valve 10' away
or I connect w/ a clip on and set the pressure at the tank
regulator.
Well kinda right only the wreckers are listed at 90 psi all others are 70 psi. Also the TM can be wrong occasionally, check out your wheels before putting that much pressure in them guys and I will check on this with CSMS and see what they say.
Andyrv6av8r
457
Spartanburg,SC
As far as CTIS pressures, I checked my newly acquired, 2012 rebuild, 923A2 tonight. The placard/nameplate in the cab says 55 psi for highway pressure. I checked it with a gauge and, sure enough, after going from Cross Country to Highway, it read 55.
MtnSnow
14
NSL, UT
FYI,
The CTIS ECU can be programmed and reprogrammed to support different pressures. My M925a2 is programmed for 70psi and my M923a2 is programmed for 60psi.
Suprman
701
Stratford/Connecticut
There is an elusive diagnostic pigtail cable that connects between the controller and harness for pc access. I believe the pc software is downloadable online. Many parameters can be adjusted. The pigtail cable was part of an update kit that included a newer revision controller and some other goodies. I looked in the newer ice diag kits and the cable is not part of that.
lakeydna
Devon, AB
Why does the tire wall say 100PSI Cold then?
The sidewall is only stating the TIRE manufactures recommended maximum pressure, not the wheel or vehicle manufacturer's. A ten ply on a pick up may say 80 psi max on the tire, but the door sticker only says to use 65 psi.
All the labels need to be read to come to the proper conclusion. Tire max pressure, wheel max pressure, and vehicle manufacture recommended pressure.
todds112
Teton Valley, ID
Sure would be nice to have one of those cables. Surely there is a techno-geek among us who can create one...and don't call me Shirley.
:p
dawico
Lampasas,TX
I just wanted to touch on this subject again.
My tires are still lumpy and I have had no luck finding a shop to shave them. I have a plan in mind to shave them myself and will post up my success or failure on the project.
dawico
Lampasas,TX
I wonder how well a hand-held door power-planer would work on the tires?
I looked at that option but the one we had handy had the motor hanging down.
The key is going to be keeping the tool stationary while spinning the tire.
Still working on my setup.
dawico
Lampasas,TX
Ok, I shaved 4 of my 6 tires yesterday with great success. I just ran out of time and will do the other two today.
The decent tires took about an hour each. The rough ones about two hours each.
I believe my setup is very simple and worked well. I took a beat up old sliding compound miter box that my dad had and adapted it. This saw flips both ways so the motor is up high and out of the way. This worked well as I could do one rear tire and flip the saw to do the other. All I really did was take the back off the sliding bars, pull the saw unit out, and slide it in the back. The saw itself is pinned down in the put away position. Then I strapped the base to a tool box for support. Jack up the axle, set the saw, and go.
I figured the slider would come in handy for adjustments but I didn't really use it. It was needed for depth clearance though. To adjust it I just moved the tool box. Light kicks to the box made cutting a little deeper easy to do.
I also followed the round profile of the tire. I didn't just go straight across. With my kicking the back of the box over for depth adjustments this was kind of a natural movement of the unit so that worked well too.
I just set the saw to shave the highest points on one edge of the tire and then kicked the back of the tool box over to cut a little deeper. Once it just barely shaved the lowest points then I pushed the unit in a little further (1/2" or 3/4") and started again.
Just take your time and don't get too agressive with the depth of cut. You don't want the saw to grab the tire and pull itself in or cut a big gouge out of the tire. Nice and easy.
I tilted the saw a little to give myself about a 45° cut on the tire surface and spun the tire into the blade (as opposed to away from the blade). I tried both and into the blade gave me better, smoother, and faster results.
I am very happy with the results of the setup and its simplicity. Besides rubber dust everywhere the saw can be returned to normal service.
I really hopes this helps somebody with the same issues. I know I had two tires that lost atleast 1/4" of tread off the high areas, and maybe more. I still feel like I will need to experiment with balancing fixes but this is a major step in smoothing out the ride.
dawico
Lampasas,TX
Here are some pictures of the setup.
By the way, this saw is available to anybody that wants to do this and can come get it. I don't want to deal with shipping it but it is free to use.
Jason O
Lebanon PA
Nice work! Have you taken the truck out for a test drive yet? I still have a bit of a shimmy at highway speed, but I think it can be corrected with ballance beads or fluid.
dawico
Lampasas,TX
Not yet. I still have two tires to shave. I have an hour drive Monday morning and I will report back after that.
My next step is balancing also.
From what I saw while shaving them I think I made a huge step in the right direction.
dawico
Lampasas,TX
Alright, now that they are all done I will give my findings on the tires in general on the shaving aspect.
I have three Goodyears and three Michelins on my truck. All six are close enough to the same age and tread wear for a general comparison.
The three Michelins were not too bad as far as flat spots and cupping go. One tire had barely even 1/16" of shaving to round it out. The other two didn't take much more than that.
The three Goodyears were a different story. All three had atleast 1/4" of tread removed in their worst areas to round them out. One was the worst by far and had obviously spent a serious amount of time on a truck with a bad shock. It was severely cupped and out of round. It took forever to shave it back into a circle.
So, if your truck has Goodyears on it and it bucks like a Bronco then this may be your problem.
Not that my findings mean all Goodyears will hold out of round and Michelins won't, it was just the case on my truck.
After doing this I am not surprised at how bad my truck was riding. I am very excited to test it on Monday and will report how it feels.
dawico
Lampasas,TX
