SierraHotel
- 4
- 18
- Haymarket, Virginia
Being that I am a lowly roofing consultant, and not an electrical engineer (and that I want to quit buying flasher units!), I’ve got some questions/clarifications for Bjorn’s relay modification. I’m sure his sketch is simple and straightforward for someone that has a clue, unfortunately it would appear I do not. I’d rather not buy yet another flasher because I misinterpreted it.
1. Is my sketch correct for the hookup of the relay? Are the A & C wires hooked up to the X1 & X2 posts or the A1 & A2 posts.
2. The relay I bought came with a diode (black with a light blue stripe) between X1 and X2, is this adequate or does the diode need to connect wires A and C after the relay?
3. Can the relay be used for other things such as the headlights and convoy lights concurrently, or is it just one relay for one item.
Enquiring (and frustrated) minds want to know…thanks Bjorn!
