- 7,547
- 10,591
- 113
- Papalote, TX
If you have the trans in park then that is not an issue as the rear transmission shaft is not turning,This probably has no association with flat towing a HMMWV, but I remember decades ago that I was told that you should never flat tow an automobile or truck with an automatic transmission if the transmission didn't have a rear oil pump. If you towed a vehicle without a rear oil pump, the spinning driveshaft didn't provide lubrication for the rear bearings in the transmission and the transmission would fail, regardless of whether the transmission was in neutral. I was told that if a rear oil pump wasn't present that the drive shaft had to be removed prior to towing, regardless of the distance towed. I don't know HMMWVs and don't know if they have a rear oil pump in the transmission or not.
