Flipping headlights
BFR
Rocket Surgeon
2,330
42
North Georgia
So for the owners with the H4 lights I assume that the upper postion is just fine for you guys (& gals)? You see a big difference when they are that high off the ground? I have been using them for 15 years or so in my M1009 and my son's CJ-7 and I love them.
Still waiting for my bulbs to come in so I have done yet installed the H4 headlamps.
jimm1009
I have Hella E-codes mounted in the high position, and would highly reccomend it.
http://www.steelsoldiers.com/deuce-...ing/19973-deuce-lighting-harness-upgrade.html
AN/ARC186
Graham,Washington
My truck came with the lights set low also, when I installed the air horns I bolted them up higher than shown in the TM so they would align with the electric horn hole.
I did this for two reasons, one , so it was not muffled and two, in the TM correct location it fires almost directly into the back of the low mounted pass side headlight causing it to vibrate filaments on that side to the breaking point.
jimm1009
71
Louisville, KY
One last question... Are those of you that have the H4 lights up high are you using the standard aiming procedures for H4 lights and then perhaps giving them an extra 1/2 turn down or...?
Thanks for all the responses.
jimm1009
Katahdin
24
Scarborough, ME
Question, when moving the headlights from the lower position to the upper position, should you also move the rubber vibration damping bolts to the upper position? Please see the pic.
SMOKEWAGON66
21
California
When I flipped mine from lower to upper, I just looked at how every thing was mounted, then moved them to the same position. Then flipped the headlight buckets etc...
Truckoholic
13
Colorado Springs, CO
Here's my 66 M35A2 wo/w with headlights mounted low,
and my 67 M35A2 w/w with headlights mounted high. I can see how if the headlights were in the lower position on the winch truck, that the bumper sticking out there so far could get in the way of the effective illumination. The federal standard for headlight height says that headlights can not be mounted more than 54 inches when measured at the center of the headlight on an unladen vehicle on level ground. And I'm pretty sure the headlights are allready higher than that on my winch truck. When I put bigger tires on it, they are especially going to be too high. Not sure how that law differs when it is on an old military vehicle that was designed that way though. I know the California highway patrol sure is quick to jump all over headlight height on any other kind of lifted vehicle.
quickfarms
25
Orange Junction, CA
The CHP will probably not hassle you If you keep the truck stock due to the federal exemption.
If you want to run standard size super singles on a M35A2, you probably should have the headlights in the low position.
You could probably get away with the standard size super singles on an 800 series, a 900 series is not an issue.
If you modify the truck with the big super singles or bob it, the CHP will probably go after the truck.
Katahdin
24
Scarborough, ME
Got it done, along with the bumper flip onto the winch extensions. Looks like the next thing I need to do is flip these brackets on the grill.
I appreciate runk checking his bolt placement, I didn't have another truck to look at.
I did break about half of the rubber bolts when removing them. The all broke on the outside where the bolts were weathered, painted, and rusted over. I replaced them with part number 9376K48 from McMaster-Carr. These matched the 3/4" rubber thickness of my existing bolts except the studs are 5/16. The original studs are 3/8" and more than twice as expensive to replace.
runk
65
Houston, TX
I bought
9213K22 Neoprene Vibration Damping Sandwich Mount, Male/Male, 5/16"-18 Thread, 3/4" H, 1"W
as a replacement, figuring I'm going to tear up a bunch of them disassembling the parts for paint. Same dimensions but neoprene instead of natural rubber. I figured the higher temperature rating was better for me down here in Texas...
All the 3/8 studs I could find also had bigger rubber sections, and I was concerned the load ratings were too high. I've used these mounts in machinery and robotics, and if they are too stiff, you might as well just bolt the parts directly together.
