flipping the rim over
junkyardog
wakefield new hampshire
on my last post on getting my tires on. some of you guys recomend i flip the rim in the rear. would i have to flip the studs around that hold the rim together also.then turn the valve stem also. would that be a strain on the studs that hold the tire to the truck.i spent a lot of money to have them mounted. i do understand what you are saying about being tippy but im going to plow snow. but i would like the truck to look normal. alltho the owner never will be normal.
MilitaryRestoration
Vancouver/Yakima, Wa
not sure if it would be a strain but no you should not have to flip the studs. When i get home ill try to post a picture of what it looks like when they are flipped and the studs on those wheels are not flipped
3,179
The wheels have the tapered area for the thimble/nut on both sides of the rim. If you don't use the thimbles, you can use the same lug nuts as the front uses, on the rear
