FLU419 intermittent no forward or reverse engagement.
Steel Soldiers is supported by:
upstateimports
I drove the Unimog yesterday for the first time and it went well (,only drove around the field) I parked it and went back out 15 minutes later and no forward or reverse gears. I recently purchased this Unimog and was told it probably needs the shift valve solenoid, can someone tell me where it is located and how to get to it so I can test it please?
I was also told the 4x4 valve was intermittent, so I need to check/test that so I am looking for location and access to that as well.
Jeff
Karl kostman
79
Fargo ND
Jeff your a lucky man since the FLU 419 was used in the US Military there should be TMs available that will tell you everything you ever dreamed of!
Karl
