General Hood
- 2
- 18
- Fort Towson, OK
Doggone it, you ARE right.I don't mean nothin'. I apologize.
There's an easy way to do it, without a crane. I'll tell you when you get here. As my dad used to say when I was a very small child and had fallen: "Come over here and I'll help you get up."Well, I found the issue on the SEE, brake shoe broke and wedged. I replaced both rear brakes, wishing I had the assist of Flufarm's crane when I went to put the wheels back on, ugh.
Now for the rest of the story (Paul Harvey Quote)........the former no air leak SEE is now air leak SEE. The bottom of the smaller air pressure tank is rusted out (bad) so it looks like I will be searching for a replacement. And yes there's more. The engine is now running rough when accelerated (new issue). Bled the fuel line at the filter canister and as luck would have it, I have air in the fuel system. Further troubleshooting to be continued another day.
I claim first dibs on the air tank off your parts SEEThere's an easy way to do it, without a crane. I'll tell you when you get here. As my dad used to say when I was a very small child and had fallen: "Come over here and I'll help you get up."
As far as the rest of your misfortune goes, it's due to voodoo. There were certain items that you were supposed to buy, but didn't.
I'll stop that spell now and let you catch up with the repairs. That decision is obviously subject to change, at any moment, for almost any reason.
PS. The paint sure is flawless, though.
I figured you would - so it's now filled with saltwater and cat urine, waiting for you to pick it up.I claim first dibs on the air tank off your parts SEE
Don't forget I'm holding 2 brand new shiny SEE starters for youI figured you would - so it's now filled with saltwater and cat urine, waiting for you to pick it up.
No fridge in the support vehicle?? May want to check fuel tank for debris before the journey, all the bouncing down the highway could dislodge any crud in the tank and keep plugging up the strainer. Also make sure to inspect the rubber boots on the driveshaft tubes, they tend to rot away. Have a safe, fun and problem free trip.....even without beer I suppose.The first two items I try not to rely on. Lady Luck is a very fickle travel companion and my wallet is not deep enough to use dollars as tools.
I will however have a support vehicle that gets me to the pick-up destination and follows me along with tools, manuals, food, sleeping bags, dogs, etc.
The beer stays in the fridge at home. Either for celebration or to ease the pain.
I'll inspect the tank and will try to get as much junk out as I can. With all the fuel system troubles talked about here I am tempted to feed the IP from an outboard tank. When that one is near empty, its time for a break and a refill from the main tank via transfer pump and racor filter that I have laying around.No fridge in the support vehicle?? May want to check fuel tank for debris before the journey, all the bouncing down the highway could dislodge any crud in the tank and keep plugging up the strainer. Also make sure to inspect the rubber boots on the driveshaft tubes, they tend to rot away. Have a safe, fun and problem free trip.....even without beer I suppose.
Speaking of the expensive and often unavailable parts used to pressurize the tanks: What do you think about removing the 'Fluid Regulating Valve', 'Antifreeze Valve' and 'whatever-not sits between the compressor and tank' and replacing this with a Bendix D2 Governor valve, a reasonably small truck air dryer with 24V heating element, and a check valve. That whole setup will cost far less than one of the Mercedes Unobtainium components and is known to be reliable and fixable with parts from any truck parts store.There isn't anything special about those air tanks. I expect if you don't use the trailer braking system you probably could get away with plugging the connection and running without one. When I bought the goodies for the air dryer install (yet to be installed), I needed a purge air tank and bought one off of Amazon which is normally used as a accumulator for air horns. Atkins Vos advertises used Unimog tanks but I expect the shipping is more than what they charge for the tank, then again with a cheap Euro its worth checking. The 1300 I bought has an air dryer, there are purge valves on the air tanks just like a SEE but talking to the Unimog expert there isn't much need to purge the tanks unless the dryer filter is getting saturated.
If you drain the tank (around the corner from the seller's, if need be) and start "fresh", maybe with some magic diesel elixir of your choice added, you'll probably be fine. Unless the inside of the tank looks like mine did.I'll inspect the tank and will try to get as much junk out as I can. With all the fuel system troubles talked about here I am tempted to feed the IP from an outboard tank. When that one is near empty, its time for a break and a refill from the main tank via transfer pump and racor filter that I have laying around.
Old bike inner tube, something really thin. the bellows is just to keep dirt out and doesn't spin, it just flexes with suspension.I'll inspect the tank and will try to get as much junk out as I can. With all the fuel system troubles talked about here I am tempted to feed the IP from an outboard tank. When that one is near empty, its time for a break and a refill from the main tank via transfer pump and racor filter that I have laying around.
I saw rotted rubber bellows of the Govplanet FLUs. Replacing the bellows on the road seems impossible unless there is a split version. Could they be wrapped with a medical gauze bandage to keep dirt out and replaced later in my shop?
I woke up last night covered in sweat after dreaming about dissimilar metals, elastomeric seals, and tiny passages in the presence of water, alcohol, rust, and emulsified motor oil. Not being able to fall asleep again I did some searches on German websites and found that the original pre- tank components are readily available for reasonable prices if one is willing to wait between 2 to 3 Weeks for delivery.Split Torque tube boots are available. A good place for 419 (a 419 is the last version of the 406) parts is this ebay store http://stores.ebay.com/Westfield4x4 They are based out of England. I see a split boot listed. Generally his prices are less than most other firms. I generally check them when I need a part as he sources non OEM supplies. They also sell boots for the tie rods which usually rot out long before the tie rods wear out (but I haven't checked the sizing).
I have all the parts to do what you propose to remove that alcohol bottle and replace it with an air dryer with an integrated air pressure regulator. The alcohol is not good for the various seals in the air system and in general the condensate formed by the engine air compressor which collects in the air tanks causes a lot of issues. I am planning to use a separate purge tank rather than trying to tie back into the air system. I have a Wabco air dryer with spin on filter I picked up on Ebay. Given the complexity of the air system I think this may be the number one upgrade to a 419 I can think of. Now I need to get the time to install it. I am also considering putting in an line lubricator downstream of the air dryer to give the system a dose of air tool oil on occasion.
Alternatively Atkinson Vos in England sells used air dryer/regulators from German 1300Ls, the issue with those systems is they are sized for the higher pressure used in the 1300Ls (and I think other SBUs) so not sure if the regulator has enough turn down to meet the 419 specs
Today's air dryers are much more efficient which led to ADIS (air dryer integrated system) in commercial trucks and the omission of the 'wet' tank.Even on the 1300L mogs with an air dryer there is also an alcohol bottle for extreme cold weather operation. I expect in a pinch it can be a back up if the cartridge is plugged. I had thought that my proposed inline lubricator could also be used in pinch for alcohol. The big unknown on a desiccant air dryer is how much oil comes along for the ride from the engine air compressor. If the air compressor is old I expect it could bypass oil and cause premature canister failure. With these SEEs which are all very low mileage it should not be an issue. Ideally desiccant should supply air down to -40 F dewpoint if everything it up to snuff.
I sent ya a message, check the notification tab at the top of the site... has a envelope as an icon...We should definitely use this opportunity to meet in person. The week after Memorial Day is marked on our calendar for this trip.
If you are heading to Atlanta in the meantime and want to look at the FLU419, please PM.
We look at this trip as mini vacation during which I may retrieve the FLU419. By preparing accordingly I want to have that option. If driving this machine to Asheville does not look like a wise choice, we will check out some things in and around Atlanta or drive back into the mountains and spend some time there. Knowing that there was no alternative, will make it less painful to pay a trucking company for the retrieval.
In any case, we should get together in GA.
