rtrask
- 270
- 63
- San Luis Valley, Colorado
Supplies List
Still no FLU, I talked to the shipper, and the army yard boss is not going available until next week. Either that or the shipper is feeding me bull, but it all amounts to it will get here next week.
So while I am waiting I have been gathering supplies. If one of you kind souls would look over my list and give me some feed back on what I have gotten so far or stuff I have missed for the initial run through, I would appreciate it.
In addition, I am going to order replacement hoses. The parts manual lists 3 preformed coolant hoses:
NSN 4720-01-225-1129 part # 406 987 5043 / 419 987 0043
NSN 4720-01-225-1130 part # 419 987 01 43
NSN 4720-01-241-4846 part # 419 987 02 43
Web Searches on those part numbers don't turn up any options. Both Euro Truck, and Expedition has them prices vary. I am concerned by Expedition, because the part number, and picture do not match diagram in the parts manual. Euro Truck does seem to match up, but no part numbers. All the other hoses in the cooling system are just cut to length with the correct diameter, so should be straight forward to replace. The hoses in the pictures supplied by GP look like they need to be replaced, but do not look like they are leaking. I don't think this needs to be a high priority replacement, but that could change after it gets here. For sure I will replace it before I put it under any kind of stress. If anybody has recommendations on hoses, it would be appreciated. As FLU farm pointed out the coolant in the storage tank went somewhere, but the GP report claims no leaks in the coolant system that could be a bad thing I just got to wait and see.
| item | FLU manual info | Discussion |
| 5 Gal AW32 Hydraulic fluid | 32 gallons (44 quarts front, 84 quarts rear) | I am only getting 5 gallons right now, I am assuming that can tide me over until I can shop around for that volume, and verify the major systems are functional / or economically fixable. If it is leaking like a sieve I may have to revisit this idea. I got Valvoline from NAPA. but I can get a 55 gallon drum of Costal for 290 + 95 dollars shipping |
| 80W90 Gear Oil - 5 gal | a little less than 2.5 gallons | More than I need for FLU, but I have some differed maintenance |
| 3 Gal 15W40 motor oil | max 11.6 / min 8.1 + 1 quart for filter | With the filter change it will be less than full, but close enough for government work. |
| 44 oz. DOT 5 silicone brake fluid. | 1 quart between the brake (.8 qt) and clutch (.2 qt) | |
| 1 V-Belt NBH 259350 | 12.5 x 900 | For the power steering pump. NSN 3030-01-247-3224 -- NAPA says this one is 12 mm x 899 mm, FLU farm confirms fit |
| 1 V-Belt NBH 259440 | 12.5 x 1125 | For Hydraulic pump, NSN 3030-00-528-3968 -- Napa says this one is 12 mm x 1127 mm FLU farm confirms fit |
| 1 V-Belt NBH 259570 | 12.5 x 1450 | For Crank., Alt., W. Pump, NSN 3030-00-529-0354 -- Napa says this one 12 mm x 1457 |
| Super Start Fleet & Heavy Duty - Battery 6TL battery x 2 | length 10.5" Width 11.875" Height 9" | NSN 6140-01-431-1172 I got it at O'Riley, NAPA could not get it to me for 3 weeks. |
| 1 case of lithium grease | It is kind of old (OK its ancient maybe older than the FLU), I inherited it from my dad, but it is not supposed to go bad. | |
| [H-1366-X]Mann-Filter European Oil Filter Element | Part # 001 184 70 25 | No NSN number in parts manual did a fair amount of searching based on Expedition and cross checking this seems to be correct. |
| 1 x Air Filter - FLU 419 (C 18 436) | NSN 2940-01-174-9142 -- lists a lot of part numbers | |
| 2 x Fuel Filter (0000901151) | Part # NPN-026 |
