FLU419 SEE HMMH HME Owners group
The FLU farm
1,497
The actual midwest, NM.
I need to dig into the valve for the left outrigger, again.
Once the fluid is warm that one will go down, but not back up again until everything has cooled off. The first time I found some debris in the bottom "cup" and thought that was the problem. Last time things looked clean, and I suspect that the sintered filter is plugged up.
Can't blow through it with mouth power, and normal cleaners don't seem to be effective.
glcaines
2,817
Hiawassee, Georgia
I had a problem with my right outrigger. Like yours, it would go down and not stop until fully extended and I couldn't get it to go back down without beating on the lever with a hammer or rock. In my case, the piston was severely corroded. Fortunately, I found an NOS valve assembly for the outrigger on Ebay. It was very inexpensive and free shipping. It was a real bear to replace because of all of the hydraulic lines blocking access, plus the backhoe had to be removed first. Once access to the valve assembly is gained, replacement is a breeze. My outrigger works perfectly now, but my FLU419 is currently still out of commission due to mouse damage to the wiring. Rain day after day hasn't helped my progress and I really need to use the backhoe.
The FLU farm
1,497
Your issue sounds a bit different than mine. For one, I haven't seen any sign of corrosion yet. Well, I can only see so much of the spool with the linkage still attached. Can't remember how far I pulled it out when the linkage was disconnected.
Also, in my case the lever moves freely until having worked the backhoe for a while. Then it only moves freely to the "out" position and back. The first time I did remove the cover for the levers so I could get to the top of the valve easily, and direct hits with with a brass punch wouldn't budge it. Using the lever would only bend the rod since it's under compression when trying to retract the outrigger.
Anyway, getting to that cap with the filter at the bottom of the valve isn't bad. Only one hard line needs to be moved out of the way to get a socket on it.
Oh, and please send some rain. We could really use it.
peakbagger
350
northern nh
The FLU farm
1,497
I have considered listing the HME there, if for no other reason because some of the Burning Man crowd might see it.
After all, it's one of the few stock vehicles that would look right in place there.
peakbagger
350
northern nh
I agree, given its rarity and military background I expect with the right write up someone would snap it up and then figure out what they would do with it afterwards.
The FLU farm
1,497
Good point. I couldn't resist buying it once I found out about them, basically to complete the collection.
There might be another one in Kansas or Missouri, but I haven't been able to verify that.
The hydrostatic drive intrigues me and I wish I could hang on to the dozer blade. Used that on a SEE for a couple of years and it was very useful.
glcaines
2,817
Hiawassee, Georgia
Does anyone have a photo of the back of the ignition switch with the wires attached? The mice, or a rat, chewed off all of the wires from the switch and took the wires away to build a nest. Unfortunately, the nubbins of the wires left on the switch don't match the schematic entirely. It is obvious that the wiring to the switch was repaired more than once during the Army days and now the rodents have come again.
Davestaco
25
13
Colorado
I went to go take a picture but it looks as though the dash has to come out, sorry.
Davestaco
25
13
Colorado
Does anyone know where to get seals for the breaker and rock drill? I have been using mine extensively and they are now leaking pretty bad. BTW, Dexpan works great!
glcaines
2,817
Hiawassee, Georgia
The hydraulic tools on the FLU419 are made by Stanley Infrastructure. You undoubtedly have a Stanley Infrastructure dealer near you in Colorado. If not, I have purchased repair parts from the following dealer in Georgia.
Southeast Railroad Tool Service
2504 Tails Creek Rd
Ellijay Georgia 30540
(706) 698-3489
They are only about a two-hour drive from me, but when I need something I order via telephone and they ship to me. Their prices have been reasonable for what I've needed and when they don't have something in stock it has only taken 2-3 days to get the part. They may be able to give you the name of a Stanley dealer near you but I'm sure they can probably help you directly. They have been great to work with. They can also repair the tools.
Another Ahab
4,947
Alexandria, VA
You are sure enough geting your money's worth out of your SEE, Davestaco; for sure.
That is a very cool spider! Got any idea what kind it is?
For scale, what's the size there of the bore hole?
rtrask
270
San Luis Valley, Colorado
Wow that looks like hard digging. No pictures of the front end loader lifting that load. I am in South Central Colorado (San Luis Valley) and realize how lucky I was with volcanic ash to dig.
rtrask
270
Apparently you haven't seen me in the 2017 world strongman competition. ;)
Of course, I wasn't in it - which is likely why you didn't see me.
I have been able to get the tires on / off by myself. To do it you need to play with the jack until the height is just right, then use a spade under the tire to wiggle it up and down until you can get a lug or hopefully 2 on. Then jack the SEE up and man handle the wheel until you can line up the other lugs. Of course it is easier if you have help, but I am pretty anti-social.
