The closest I get to that kind of fun is placing Tannerite by prairie dog holes. And even that is a rare occurrence.I do miss working utility construction years ago, they did all their own blasting on occasion and setting off a couple of hundred of feet of trench with timed caps was impressive. They just used sticks no powder.
Yes, either what you use for the engine or in the hydraulic tanks. No need to stock another fluid.I'd ditch the 10W and put AW 32 in there, too.
Tannerite's claim to fame is about making a lot of noise with little destructive effect. It's fun on the shooting range or on your own property for giggles but unless you use tons of it (or its cousin ANFO) not very useful as a land clearing and site preparation tool.The closest I get to that kind of fun is placing Tannerite by prairie dog holes. And even that is a rare occurrence.
The expanding mortar mixes like Dexpan will work very well with the drill bit diameters and lengths of the FLU419 tools for rock breaking or removal of old foundations.I haven't done it with the SEE yet but at my old job we used "slow dynamite" on occasion. Far less dramatic but we had old buildings with papermachines in them and the staff was paranoid about regular blasting. Just drill the holes (lots of them) mix up the powder with water, pour it in and go home. No need to cover or worry about licenses, or foundations cracking as there is no explosion. In the AM the rocks would usually be split. It didn't work as well with old concrete with rebar but usually was good enough. Far less dramatic but a lot more accessible, no license needed. An adjacent town is mostly in granite and they have been replacing water and sewer lines as when they original went in they put them in shallow and let folks run a tap all winter. They had a blasting contractor one year but the hassle of having to pre inspect all the nearby homes and the inevitable claim's, they switched over to big ramhoe and slow dynamite for a good ten years.
The Gold Rush TV show used some of this product last season. They acted like its a miracle. I was surprised they drilled so deep. Up in New England most farmers split their own granite with feathers and wedges and they usually only drill in about 6".
In my case it works just fine, the objective being to kill prairie dogs in a different way than simply shooting them.Tannerite's claim to fame is about making a lot of noise with little destructive effect. It's fun on the shooting range or on your own property for giggles but unless you use tons of it (or its cousin ANFO) not very useful as a land clearing and site preparation tool.
If was not sitting, there could still be pressure on the back side of the piston although not likely. The vent was completely plugged which makes the cylinder go in a little until air leaks by the piston and makes the cylinder extend. I was able to remove the cylinder from under the back of the cab without tilting.Exactly the kind of response I was hoping for. Thank you. Three questions, first what does letting it sit for a while have to do with anything? Second, Wouldn’t a plugged vent just make the cylinder sluggish but still functional? Third were you able to get at this vent and paint without tilting the cab?
Voted for you but the old International wrecker is going to be hard to beat. Good luck anyways.We invite you´re all to have a break between all that work.
Have a look at https://www.steelsoldiers.com/showt...l-Soldiers-MV-of-the-month-2018-May-VOTE-HERE!
As a SEE owner we need some support.
View attachment 728501 View attachment 728502
but that was about it.
