FMTV High Speed Gears
748
Woodstock, GA
No and NO there both open diffs..
Is there perhaps a variant of the LMTV that does have locking diffs? I've been researching this but I keep coming up with conflicting information. In particular I have found several places claiming that the LMTV's have "Full-time All-wheel Drive and Integral transfer case with locking interaxle differential".
748
Woodstock, GA
Yeah, I saw where that was said, before I posted. However, since I've seen conflicting information, I was hoping that someone else might shed some light to show that the prototype locker wasn't the only option.
steve6x6x6
Winter Haven, florida
The Detroit locker PN # 225-S-92, for all LMTV.
OK the rest of the story. These DT. lockers were obsoleted in 2002. I have talked to Brent, (we go way back into the 1990's) he is the Engineer inside Eaton. I have looked into another option for a locker but it to was obsoleted to in 2002. 11 million dollars of Trac-tech's inventory in 2006 was scrapped when they were bought out, the very items we are looking for. I am working on a heavy duty locker for the LMTV that will require machine work to the carrier for it to fit. The (4) pin size would be changed from 3/4" to 7/8". I would need your carrier in exchange, i have some to get started.
NDT
7,530
Camp Wood/LC, TX
It was basically a wash for me. 6.5 before and after
I'll never understand why a modern turbocharged/intercooled empty 17,000 lb diesel truck gets the same or worse fuel economy as a loaded 80,000 lb class 8 big rig.
Terrh
Detroit, MI
Underpowered.
okay, but my 7.3 truck with 15klb behind it is just as underpowered, weighs more, has worse aero and gets more than double the MPG.
I think there a bunch of factors, this has bugged me a lot too. I have gotten 11 MPG in my freightliner grossing about 60,000lb. (proof) http://i.imgur.com/5hbLRlh.jpg
One of the biggest factors has to be gearing - my freightliner spins 1300rpm at 55mph.
Full time AWD can't be helping either, and I suspect that those CAT engines are just fuel pigs by design.
It would be interesting to find one with a bad engine and do a 5.9 swap and see what the MPG does.
