Trooperuss
- 0
- 0
- Saskatoon SK
For those of us who are not familiar with the wreckers that are being referred to, can we get some contact info for each place that has axles available please?
Hi All !!Can you do both? Dual T with axle gear change, at the same time. Would that yield higher highway speeds and still allow crawler type gears in t-case? (novice question, from a novice)T case change will give you a 7 mph gain at same rpm. Axle gears gives you a 15 mph gain
2012 - purchased directly from BAE in Sealy, right before they closed up shop.Ok
your truck looks like a new one. What year is it?
justin
It is the Cummins.Nice. Congrats on a nice buy. Is it a Cummins powered truck?
I pull trees, run in deep mud and sand, tow 15K+#
don't feel like the truck is lacking but it has also been reprogrammed
