Radiator/Inter-cooler lift assembly
I started last week on getting the truck ready to change the broken timing cover. In order to do that the camshaft needs to be removed. This requires that the radiator/inter-cooler to be removed to allow you enough space to remove the camshaft. Since I do not have access to a A-frame or overhead crane I had to improvise. I ended up making a mount that attaches to the front air lift sleeve. The crane I built a year ago for the back of the FMTV bed will now come in handy. Here is a photo of the crane mounted in the new fabricated bracket. I do need to extend the top part of the crane with an additional tube for 2' longer reach. I will then pick the radiator/Inter-cooler up and place it in the bed of my truck. Once this repair is completed, I will remove the fabricated bracket and add end caps to the 2 x 4 square tube used to fabricate this assembly.
Since I installed the camper body on the back of the truck, the crane has just been sitting in the garage until I can find a new place to mount it. I am thinking about making a similar bracket that would come off the back of the truck, to allow me to permanently mount it there. Never know when you will need to lift something.
