Found $7.00 MEP 701/016 Fuel Filter
rivercreek
Berryville, VA
Public Service Announcement: MEP 701/016 Fuel Filter replacement:
Carquest #86516 $6.95
Beats the heck out of the $30 + dollar filters listed on Ebay!
Beerslayer
54
Tualatin, Oregon
You're a prince of a guy, thanks! Great 7th post or so. You put in;;; What, Where, and How Much. Again, I thank you, I was looking for that same part.
ClarkeF
Hestand, KY
Here are all the cross references for that fuel filter.
CARQUEST 86516, CASE A35667, CASE A35863, CASE A36557, COMMERCIAL PRODUCTS X13R316, FLEETGUARD FF244, FRAM C2100, GMC 6438089, NAPA 3516, WIX 33516 *
PeterD
Jaffrey, NH
The CarQuest part price may have increased since the original post... I am showing it on my CarQuest terminal as about $9 now.
ETN550
9
Knoxville, TN
I paid under 8 for the same carquest a few weeks ago. The cross references are very helpful. I second the fact that these filters work perfectly. The Carquest version does not supply the correct size top oring for the lid. However, the existing o-ring looks to be square section and should last 10 years or better. And I would assume it could be taken out and matched up easily enough.
Thanks for posting!
ClarkeF
Hestand, KY
Does anyone know how to remove the filter on a 701a? The nut on top is under cover and from eyeballing it, it doesn't seem accessible?
Any tricks to getting access?
ClarkeF
Hestand, KY
Isaac-1
SW, Louisiana
I am like the others in saying remove the top cover it is held in with about a dozen screws, watch out for spinning threaded inserts though, if you get one spinnng once you get the screw out skip that one or repair the insert before putting it back in, I have removed mine a couple of times. I do have to wonder what the official way is as somewhere in the manual it says something about the top cover not being a field removable item (my guess is to minimize getting the spinning threaded inserts)
Ike
R0E0D
EASLEY SC
i did not take the top off if you work it just right. u can get the top off and the air filter out. now any one found a air filter that will work?
R0E0D
EASLEY SC
The fuel filter has a primary and secondary stacked in a canister mounted to the frame. I don't think it really matters.
