xjrockrawler
- 0
- 0
- wilmington nc
i need to replace mine also... looks good
I beat the ever-loving snot out of that sucker every time I take this apart. It seems to be more of a pain in the rear every time I remove it. I think the most effective method was to strike the arm near the connection with the drag link, then drive a chisel under it once a small separation appears.Any ideas on removing the steering arm from the steering knuckle? I just searched the -20 TM again and can't find any info on this.
OH, and p.s. I was able to borrow a slide hammer at Autozone free of charge. $80 deposit to take it out but refunded in full when I bring it back!
You don't need any loctite on the seal to retainer interface. I used #2 permatex on the seal to retainer interface and on the edge of the retainer where it seats into the axle housing. Used gaskets and #2 permatex on the axle flange.OK the slide hammer took the seal retainers out easily, but then I found I did not have an item the right size to press the seals out of the retainers (I have an arbor press). But the neighbor's air hammer made quick work of them.
One of the seals looks like it was red loctited in place. Is this necessary or desired? I don't think the other seal had any goo around it.
Just to summarize: in the course of reassembly I will use black RTV gasket maker in 3 areas: in seating the axle seal retainers (with seals already installed), on the spindle when it bolts to the steering knuckle, and then on the outer axle flange (first thing we took off after the wheel).
However, in another thread, Heavysteven experiences torn boots (newly installed) because he did not bend the bolts. Who is right in this matter? And if you do bend the bolt, do you bent it to match the contour of the knuckle?IMPORTANT POINT No. 2: USE A SELF LOCKING NUT ON THE INNER AND OUTER CLAMPS! If the new clamps you bought do not have self locking nuts, go down to your local hardware store and buy locking nuts. If the new clamps have metric threads and you cannot buy a metric locking nut to fit, buy a US (SAE) nut and self locking bolt to replace them. The SAE Bolts will not be the same diameter and length as the metric bolt, so buy the next larger diameter and next longer length SAE bolt. The extra length will not be a problem, but if you buy a shorter bolt it will be a real PITA to get the nut started on the bolt. This is the voice of experience talking! Also, the manual says to bend the bolt after the clamp is secured (presumably to prevent the nut from loosening). DO NOT BEND THE BOLT!. User a self locking nut and it will stay secure. Then if you have to remove the clamp for any reason, you can remove the nut & bolt without a problem.
JCKnife,.,.. So now I need to wait on another clamp to get here and probably not going to make it for the parade on 9/15...
JCKnife,... Do the kingpin bushings need any RTV / permatex sealant?...
Did this yesterday; backing out the broken bolt was so easy, at first I thought the extractor was just spinning and not catching. But it came right out. Had me scratching my head what caused it to break in the first place (I did hit it with PB Blaster but still...it came right out with no fight!).I wouldn't abandon ship that quick on the broken bolt. There is nothing special about the bolts. I don't believe they are even grade 8. A good drill bit, extractor and patience can do wonders. A lot cheaper than a hub, but then again I have more time than money for these things.
