For Tie Rod removal you could try "shocking" the taper. A couple hard whacks on the side of the spindle arm usually do the trick. I've used this method to great success. Works on tie rods and ball joints w/o damage to boots or threads. I would thread the nut on a bit to catch the part as it pops out.
Hope this helps.
What he saidsubscribed
what Countryboy21 said. That was the hardest part to get off of the entire process when I did the bushings, bearings, brakes and seals. Hitting like it said in the TM didn't even budge mine. Liberal application of penetrating oil and working the cones out with a small chisel was the ticket.
