- 3,923
- 77
- 48
- Comfort, Texas
I started my front axle service using Banshee365's PDF and everything went south in a hurry. I drained the differential and oil was the consistency of pancake batter. It was not brown so I am not sure about water. Once I removed the wheel hub I knew I was in trouble. There was oil contaminated by water and gobbs of grease. The bearings were pitted and I knew this would be one **** of a ride.
I worked my way through the steps and cleaned as I went. I will remove the first steering knuckle tomorrow and start on the other side. When I get that cleaned I will used my trusty new rod to remove the axle seal retainer. One final cleaning and the boot fun begins.
In preparation, I have these questions. Is there a gasket to go between the deflector and the spindle? I know the TM calls for a sealant but what is the right one? Also, when I preload the new bearings, do I used the same torgue specs and the rear axle?
Thanks, Oh, I am sorry there are no pictures but I was up to my ass**** in grease.
