front brake drum
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
To pull the drum, all you need to do is remove the two nuts on the spindle, you are correct. If you have trouble getting it off, see if the brake pads are in contact with the drum. If the drum spins freely, the pads shouldn't be touching.
