Lieutenant Dan
- 6
- 18
- Reading Pa
What springs the retainer springs or the return springs?
I'll agree with this too. I've had this happen and experience the same thing when I thought the surface was just fine.Sounds like they are glazed.
I'm hurt Dan ! Didn't you read my post ? Just kidding. The sand trick is easy. You just put fine sand into the brake drum and go and stomp the brakes a few times. You might have to get creative in how you get the sand into the drums since the backing plate doesn't come off.Yeah it is super embarrassing.
Rosco how are you doing the sand trick? I've never heard of that before. I'm going to try a long hill today hopefully and see what that does.
Play sand might be a bit coarse. But if you sift the gravel out and use only small amounts at a time it should be fine. Maybe less than a 1/4 cup or so. It doesn't take much.Lol now come on my tires are badass.....
I'm seriously thinking about trying this. .... will play sand work?
